Create part name in a note
SOLVED
Newbie
How can I get the part name in a note? I have tried &model_name, but then the name of the assembly is displayed.
Re: Create part name in a note
Another way to do this is to find the part's session id.
Open the relations dialog (Tools tab > relations) and then pick Show > Session ID, pick Park in the pop up menu and then pick the part in question on screen. The session ID will be shown in the message area. Then create a note with this text '&model_name:ID where ID is the number you just found.
Another method would be to create a user parameter in your part tied to the file name. Enter the relation file_name = rel_model_name in the part's relation and then use &file_name:att in your note attached to the model.
LinkedIn
15 REPLIES 15
If your note is attached to the edge of the model in question (and not an edge created by a section, for example), you shoudl be abel to use &model_name:att).
LinkedIn
Doug,
Is the ":att" the number of the model in the assembly? How do you find that number?
Thanks, Dale
Doug,
Ik cut and paste your command in my note, but it doesn't work. I have selected on entity and on surface. Knipsel.PNG
Off the top of my head I believe the syntax is: &model_name:att_mdl
Hmm, I've always used the ':att' suffix and it has worked. Proe / Creo will convert it to :att_mdl.
I just tried both in Creo 2 and they don't work. Opened the same drawing in WF4 and it didn't work there either.
I tried it again using a user created parameter and it worked fine. I guess it doesn't work with system parameters. Odd.
LinkedIn
LinkedIn
Doug!
It works, thank you!
What method did you use - the ID?
...if I need to check the corect information "att_mdl" for note in drawing - I create "fake relation" in assembly mode - system automatically create for me information (behind parameter in relation) and then I can use this number to my note in drawing
For example:
Best Regards,
Vladimir Palffy
Now I have made a "mapkey" to search for the session ID. In the mapkey is also the command for making the note. It takes seconds to place the part numbers in a assembly.
I like mapkeys too -
Here is some Trisks with Mapkeys and video Hide custom Layers with Mapkeys
Best Regards,
Vladimir Palffy
Nice! Personally, I would have gone with the parameter & relation so that the note is tied to the part it's attached to but either way works.
BTW - I have a good friend named Stefon Lowman.
LinkedIn
don't mean to thread hijack 😉
is there something similar for zone locators?
I have created idea for new release
What do you think? Vote here: Enable Show/Hide Session ID in Model Tree
Best Regards,
Vladimir Palffy
For some reason I have found that I have to enter the parameter in lowercase &model_name and uppercase &MODEL_NAME does not work. For multi-part drawings, whatever model I have active, ProE / Creo will append the correct number at the end e.g. &model_name:12
