Create part name in a note
sloman
How can I get the part name in a note? I have tried &model_name, but then the name of the assembly is displayed.
1 ACCEPTED SOLUTION
dgschaefer
(To:sloman)
Another way to do this is to find the part's session id.
Open the relations dialog (Tools tab > relations) and then pick Show > Session ID, pick Park in the pop up menu and then pick the part in question on screen. The session ID will be shown in the message area. Then create a note with this text '&model_name:ID where ID is the number you just found.
Another method would be to create a user parameter in your part tied to the file name. Enter the relation file_name = rel_model_name in the part's relation and then use &file_name:att in your note attached to the model.
LinkedIn
15 REPLIES 15
dgschaefer
(To:sloman)
If your note is attached to the edge of the model in question (and not an edge created by a section, for example), you shoudl be abel to use &model_name:att).
LinkedIn
Dale_Rosema
(To:dgschaefer)
Doug,
Is the ":att" the number of the model in the assembly? How do you find that number?
Thanks, Dale
Doug,
Ik cut and paste your command in my note, but it doesn't work. I have selected on entity and on surface. Knipsel.PNG
Patriot_1776
(To:sloman)
Off the top of my head I believe the syntax is: &model_name:att_mdl
Hmm, I've always used the ':att' suffix and it has worked. Proe / Creo will convert it to :att_mdl.
I just tried both in Creo 2 and they don't work. Opened the same drawing in WF4 and it didn't work there either.
I tried it again using a user created parameter and it worked fine. I guess it doesn't work with system parameters. Odd.
LinkedIn
dgschaefer
(To:sloman)
LinkedIn
Doug!
It works, thank you!
Dale_Rosema
(To:sloman)
What method did you use - the ID?
VladimirPalffy
(To:sloman)
...if I need to check the corect information "att_mdl" for note in drawing - I create "fake relation" in assembly mode - system automatically create for me information (behind parameter in relation) and then I can use this number to my note in drawing
For example:
Best Regards,
Vladimir Palffy
Now I have made a "mapkey" to search for the session ID. In the mapkey is also the command for making the note. It takes seconds to place the part numbers in a assembly.
VladimirPalffy
(To:sloman)
I like mapkeys too -
Here is some Trisks with Mapkeys and video Hide custom Layers with Mapkeys
Best Regards,
Vladimir Palffy
dgschaefer
(To:sloman)
Nice! Personally, I would have gone with the parameter & relation so that the note is tied to the part it's attached to but either way works.
BTW - I have a good friend named Stefon Lowman.
LinkedIn
don't mean to thread hijack 😉
is there something similar for zone locators?
VladimirPalffy
(To:sloman)
I have created idea for new release
What do you think? Vote here: Enable Show/Hide Session ID in Model Tree
Best Regards,
Vladimir Palffy
For some reason I have found that I have to enter the parameter in lowercase &model_name and uppercase &MODEL_NAME does not work. For multi-part drawings, whatever model I have active, ProE / Creo will append the correct number at the end e.g. &model_name:12
