Creo 2.0 M070 efx failed to load.....
Newbie
Dear All,
I have installed Creo 2.0 M070. I have configured everything properly. AFX is enabled properly. Now when I am starting Creo it give a message that efx is failed to load. i know that the configuration efx is not in the newer versions of Creo and it's Configuration is AFX Enabled=Yes. Kindly help in this issue.
Thanks All
Re: Creo 2.0 M070 efx failed to load.....
Check if you have EFX folder in
.../Common Files\M070
Software consultant for PTC products.
there is no efx folder in Common Files\M070.
AFX is not Working. Installed properly and problem in loading.
I am not sure with M070, however in M060 is EFX folder. Check your installation an Advanced Framework (this option is default uncheck)
thanks alot I got one point here. I am checking and I will get back to you.
