Creo 2.0 table repeat regions
lfox
I'm trying to make a customized BOM table that will play nice with external software when exported as CSVs.
The columns I need are as follows: Parent, Parent Revision, Child, Child quantity, Child Description
The last three are easy, typical repeat region setup for BOM. The parent columns are the problem. I can grab the parameters from the assembly, but they do not repeat in the table because there is nothing to repeat. I need the same parameter pulled in for every row on these columns. Is there a way to make the same "value" repeat with the rest of the table? See attached.
I am aware of some other software and methods for exporting BOMs, but this is the way we need to do it for now. Thanks in advance for advice!
lfox
(To:lfox)
I figured it out. I had multiple repeat regions set up instead of one spanning all columns. Spanning all columns made the "constant" parameters just show the same in every row.
lfox
(To:lfox)
Mahesh_Sharma
22-Sapphire I
(To:lfox)
YOu may accept your comments to post as solution and close the task.
