Applies to Part mode (Modeling) and Assembly mode.
Has anyone run into where the Part surface layers are off but the surfaces are still shown?
Seems to glitch after running Creo 3 for several hours, then all of a sudden the surface are shown.
Surfaces are visible in Shaded mode, when you go to Wire frame the surfaces are not shown.
Also if you change the color scheme this will clear them as well.
Confirmed on M040 / M070 Win 7 x64, Multiple PC's and Laptops with different video cards and drivers.
Have not opened a case with PTC yet..
Jeff Lippeth
<JSCOTT>
I have found this after redefining a feature in the middle of the model tree. It goes away if I switch to the layer tree and then back to the model tree while working in Creo 2.
Only on models with a lot of features.
