I just upgraded my Creo 2 to Creo 3 and i'm doing config files.
I made a custom color config file (syscol.scl) and added in the "config.pro" file the patch to load it (system_colors_file parameter).
When i open a drawing, i does have the custom colors.
But when i go to File/Option/System colors/ , the good path is wrote and when re-select "Personalized" the custom colors are applied.
I probably forgot a parameter in a config file, could you help me please ?
Best regards,
Problem solved !
I just found wrong parameters in the config.pro file ( "system_background_color" and "system_geometry_color").
I deleted them, and it works !
Problem solved !
You may accept your reply as correct answer for the post.
