Creo 4.0 Assembly Constraint Menu not appearing when I assemble a new part or sub assy into the assy
SM_9575840
I have restarted my workstation , but it still does not show up, I have been working on this assembly for a few days w/o any issues until this AM
-Thanks
-Steve
@SM_9575840
See post I think this will help
I renamed the .wf file & now all of my saved settings have also disappeared as well!
@SM_9575840
Seems your UI settings were saved in .wf. Reset back to original.
There was another solution for that Post ... more specifically it is
 "Rest Panels Position" is available under File > Options > Window Settings "Rest Panels Position".
BenLoosli
23-Emerald II
(To:SM_9575840)
Your saved settings are under the .wf folder you renamed.
Copy the .settings file from your old renamed .wf folder to your new .wf folder.
