Creo Cam follower coonection not defined
Highlighted
Newbie
I'm in engineering class and I'm currently working on a caterpillar cam toy.
I'm trying to figure out how to define my second cam (the follower) for the mechanism.
When I select my fllower pole surface, it says " please sleect some cam geometry.
I have no problems defining my cam gear (concentric)
I have attached an assembly with my parts.
Highlighted
Re: Creo Cam follower coonection not defined
Highlighted
Highlighted
I'm facing the same issue. Cam surface is not taken for spherical surface.
Any solution ?
