Creo Family Tables?
Newbie
Creo Family Tables?
Why is it some of my assemblies don't show up in my family table instance, though I added it to the table and checked it with a Y. I have regenerated and checked for any errors in my assemblies.. there are none.
Tags (1)
11 REPLIES 11
Re: Creo Family Tables?
Diane,
I guess that "missing" assembly is dependent on "item", which is suppressed in FT instance.
Martin Hanak
Martin Hanák
Just to expand on Martin answer (which is fully correct) :
1. while adding Y or N instruction for certain feature to a table, you implicitely command to [silently resume parents for features with Y instruction] and [silently suppress children of the feature with N instruction]. This is to avoid immediate regeneration failure.
2. if you have a conflicting instructions in family table of a kind "suppress parent of A" and "resume child of A (or resume A itself)" the "winning" instruction will always be Suppress instruction - "suppress parent of A", which eventually will suppress A along with its parent.
Thank you for your response, but I am still confussed.
Is this a situation where if I have several assemblies in a master assy that are the same part number, they will follow a suppress command since the previous row had them turned off? Doesn't that defeat the purpose of family tables. Ordinarily, I would use simplified reps, but our employer doesn't permit us to use them. I am really very stuck. Any other suggestions?
Well, let me clarify. there is no difference between same or different part numbers. What matters is if componets placement depend one on another.
So say you have two components A.PRT in same assembly. Second A.PRT is placed using geometry of first A.PRT. You add both of them to family table as a component members. Select to Suppress (Y) the first, and Resume (Y) the second.
because the above explanation and components parent-child dependency second A.PRT will also get suppressed.
if you want them to react independently to Y / N instructions you need to ensure that their placement in assembly is independent of each other - directly and indirectly, I think this fits common sense as well.
Hi.. thanks for the help,
I am not suppressing anything. And My individual assemblies are individually tied to the master assembly Datums and not each other. Any Ideas?
hmm ... this is less clear then, at least not easy to say without seing the models. Probably contacting TS to have a look at the design ?
Is this in the part or in the BOM?
Next Question... How do I delete the table instances if I want to start over?
I have 10 assemblies that I have added to a master assembly. All attached through datums.
