Creo Mouse Lag with windows 10 1903
Highlighted
Regular Member
I recently upgrade to windows 10 1903  enterprise   November   update. I got problem in both creo 5 and 6.
When the assembly is small (like single part), everything seems ok. when the model gets complicated, like 30 parts, i got sudden huge  lag when suddenly drag mouse to pan zoom.  it's not always happen,  lag for the first second, then good for a little while  . After little while, it starts lag again, i rotate the model a bit, then good again, then repeat.
The "good" period seems like it's reading cache of current model.
I also noticed both verison of creo are stongly use signle core single thread now(i know CAD is single core, but before wasn't like this).  When i rotate model now, only single thread is 100%, lag is gone when that thread is low. Now the performance is waaaaaaay lower than my Core i5  6600 with nvidia gtx750.
No lag with manual click Pan Zoom under "Zoom" tab, no lag with mouse movement on screen(like i could play games...), just model lag when manipulate with mouse.
system is windows 10 1903 build 19025.1051, intel 5960X@4.3ghz, 56gb ram@2400mhz, Firepro w9100, monitor 1080p.
Creo are  6.0 M010 and  5.0 M040.
Thanks.
13 REPLIES 13
Highlighted
Re: Creo Mouse Lag with windows 10 1903
unable to upgrade to newer creo for now. Did try reinstall or play with BIOS.
update :
Temporary switch to Group B in AMD Radeon GPU driver Platform Compatibility.
Current driver version for Firepro  GPU  is 2019 .Q4, Known issue happens same on 2019.Q3 and 2019.Q3.1
With Group B setting,  i think i lose all GPU feature like SuperSampling , ECC GRAM,  8xEQ Anti Aliasing....
Highlighted
the following recommendations are "without guarantee".
1.] set following config.pro option temporarily and test Creo behaviour
graphics  win32_gdi
2.] it seems to me that W10 "big" update can "corrupt" graphic card drivers,
therefore I am suggesting uninstall/restart/install graphic card drivers
Martin Hanák
Highlighted
Hi Martin,
Thanks for helping !
however, win32_gdi wont help that lag, tried before post.
driver refreshed/upgraded, not work.
also tried
use_software_opengl yes
graphics win32_gdi
spin_with_notes to no
spin_with_silhouettes to no
display_silhouette_edges to no
edge_display_quality to normal
shade_quality to 3
shade_with to no
none of works.
Any idea?
Highlighted
my tips follow:
1.] uninstall 1903 update to see if the problem disappears
2.] report the problem to PTC Support
No other ideas 😞
Martin Hanák
Highlighted
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS169272
You can also test following config.pro options
enable_opengl_fbo no
enable_opengl_vbo no
enable_opengl_shader no
Martin Hanák
Highlighted
Rollback to 1809 is definitely  a worthy try, i can do that. i just contact AMD support, going to wait couple days, hope someone from PTC could address issue under thread.
I did't purchase PTC support, Im more like using Creo for academic now,
yup, need PTC insiders, begging for that pro GPU could brings some pro support from PTC.
Highlighted
May i ask what are "enable_opengl_fbo no"and "enable_opengl_vbo no"?
Highlighted
FBO - Frame buffer object. Instead of rendering opengl data in screen window buffer (buffer which belongs to the OS window which is displayed on screen), everything is rendered in offscreen memory area which are called frame buffers. Once drawing finished, contents from framebuffer is sent to OS window for display on screen.
VBO - Vertex buffer objec. All 3d data (vertex, normal etc) is stored on the graphics card via VBO. OpenGL gives us an id for each VBO we create on the card. Once created rendering is very fast because everything is already on the card and all application need to do is to enable a given VBO visits ID.
Shader - instead of asking opengl to do lightingcalculations, we upload customer programs on the card so that we could do better lighting calculations. OIT (order independent transparency), phone lighting etc are possible only because of shaders.
Martin Hanák
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
