Creo NC - Constant_load retract distance issue
Guest
Trying to do a volume rough, constant load with minimal retract.  Volume to be milled is "L" shaped.
Image #1, I've set the Approach-Wall at red arrow. Image 2 is resultant toolpath.
The first leg of the "L" it machines as expected (with minimal retract between climb cuts, nice).  However I can't figure out why it is retracting on the second leg to the top surface of the part (actually, it is retracting above the top surface by LIFT_TOOL-CLEARANCE distance of .005").
If I change Approach-Wall to other end of "L", result is the same (image 3).
Now, if i remove all Approach-Walls, it does a helical plunge in the corner, and then does the constant-load, minimal retract path exactly as i would want (image 4).  trouble is that i do not want to helical plunge, I want to enter from the approach wall!
seems like having (any) Approach-Wall selected is making it retract on the long run of the "L" for some reason...
Anyone have any ideas?  Thank you for looking
NC assembly attached.
Creo 3.0 M040
some notable parameters:
scan_type constant_load
Rough_option Rough_only
retract_option optimize
min_retract_distance 500
cut_type climb
lift_tool_clearance .005
Re: Creo NC - Constant_load retract distance issue
I ran your attached file and it looks ok to me
-Josh
