Creo assembly with siplified reps - Need creo view and easy filtering method
Highlighted
We wanted to create a fairly complex assembly for fuel dispenser. There are more than 400 different types of assemblies using same parts going in different places or in different set of combination. In my experience it is always difficult to handle so many children in Creo family table so I have created simplified reps.
The purpose is solved and I could get all parametric BOMs, the assembly is not so heavy to open in creo.
Now we wanted to share the 3D models with operators on the floor. I could worked out a way to get the 3D creo view on the TV hooked up to workstation in the assembly area. But the problem is they are having hard time filtering the right assembly number to view.
Is there anyway I can pull all these creo views (latest version as per windchill) in a PDF format or may be creo illustrator? What is the best way to handle this model?
Any help highly appreciated.
