We just purchased IFX licenses and I am working on our setup. I have successfully created the files for screws and I am able to populate the menus for different types of screws. Now I am trying to create the files necessary for nuts. I am setting this up for Creo 5.0.1.0. I have created a custom directory for our IFX data. In that directory, I have files named Excel_ScrewType_20.dat. This file works. I created a similar file named Excel_NutType_1.dat.
I then modified the IFX catalog file as shown in the screenshot below.
When I restart Creo and insert screws using IFX, the nut option is grayed out. What am I missing in my setup?
Matt
I removed the last column from my nuttype file. After doing that, I was able to get it to work.
Matt
Hi Matt,
can you send me your fastener files, please. Then I can review it.
You can send it directly to me: oli@buw-soft.de
Oli
Matt
