Hello All
I want to simulate a cylinder head(A) and base(B) assembly unit to check the structural integrity under working loads.
I Am new to CREO.
HEad unit (Part A) is threaded into base unit (Part B).
THe base unit is subjected to 5k psi internal pressure.
what should be the way to approach this problem in CREO ?
IDeally I would preload equal to threading torque in step 1 & apply internal pressure in step2.
DOes CREO have similar capabilities?
HElp will be appreciated.
REgards
VInay
