Hello, I am tired of choosing all files every time. Is there any way to keep option "all files" as default one while importing.
Hello @Ananth_Narayan please confirm which product you are using so your post can be moved to the appropriate product board for more exposure.
I use Creo Parametric.
please provide more details about import action you execute.
When I start assembling file of other formats (say .stp). I click on assemble and on the bottom it shows part file (.prt)- creo files. I will now choose all files and then choose the stp file. What if the part file is removed from default list and keep all files options so that I no need to change the option every time.
I don't think there is an option to change the default type of file to be assembled to "All".
And if you find yourself doing something repeatedly, you should consider recording a mapkey...
Mapkeys can be assigned to a button on the ribbon or the quick-access toolbar.
I am not sure of map key, can you provide link to assign map key. Have a look at this video https://www.youtube.com/watch?v=dGafJHgppD0 from 0:22, when the person chooses assemble the file type is set to all files. If this person can have this setting, there must be a way which I am unsure of.
according to https://www.ptc.com/en/support/article?n=CS38304 setting Type=All Files is not possible. I suggest you to open Case at PTC Support and send them the link to youtube video.
How can you be sure the video is not edited? As for mapkeys - please search the forum, these have been discussed before plenty of times.
