Detailing Multiple Coordinate Systems with showing only 1 per sheet
DaleHvizdo
I am trying to detail a print with a assembly on multiple sheets. I have
several coordinte systems in the assembly but would like to only show one
per sheet. If I hide or suppress a coordinte system it will effect the
ofther sheets. Is there a way to do layer control per sheet? If not what
steps would I take to resolve?
Dale
Dale,
In the layer tree you can specify the layer settings per view.(See
below). This will enable you to define exactly what you want to see per
view and consequently per sheet.
Iain
Iain Lewis
Principal Application Specialist
iCenter UK
