Dialog box
emathivanan
1-Newbie
Dialog box
when im doing some of the operations in assembly i cant press OK because of my dialog box going out of the screen.. IS there any ways to control. im using creo 2.0
2 REPLIES 2
Chris3
20-Turquoise
(To:emathivanan)
Not sure what operations you are talking about but usually middle button clicking is the same thing as clicking the "OK" check box.
dgschaefer
(To:Chris3)
Using the MMB for "OK" is not necessarily reliable.  It frequently means OK, but often means cancel, new or does nothing. I think it should be consistent, and [shameless plug alert] created a product idea for that.
Elango Mathivanan - Can you drag the window back on screen? Do you perhaps have your screen resolution set too low?
LinkedIn
