Disable Automatic regeneration of model
Highlighted
Level 4
Is it possible to stop automatic regeneration of the assembly model.
I have tried disabling the parameter "enable_auto_regen"
That does not seem to help as it gets back to default once we get back
Tags (1)
2 REPLIES 2
Re: Disable Automatic regeneration of model
DId you save the config option? You need to select the pull-down menu where it says something like "Current" and find where it says "config.pro" Then add the configuration option and select 'Save'
You can also use a text editor to add the option to the config.pro file.
Yep i did try the same but that does seem to help
