Disappearing parts in CREO Elements 4.0/laptop capabilities?
ptc-4561143
I have the free version of Creo Elements 4.0 installed on my laptop. When I try to sketch a part it dissapears from view as soon as my mouse is moved away from it. Once the part is extruded you can only view it if you click where you think it is and then in disappears again. This makes it impossible to work with. Is this to do with my laptop and is there a way around the problem?
My laptop is a 2008 Dell Inspirion with an Intel Celeron dual core processor and 2 gig of RAM. I would be amazed if it had a separate graphics cardbut I can't see what it has. Is this a case of buying a new PC/laptop or altering a setting in CREO, not looking at making huge assemblies at the moment?
Thanks for any help
Steven
A descent graphics card makes all the difference. It is expensive to get a laptop that will run PROE efficiently. Your best bet is to customize your own desktop. I did this many years ago for around $450. I put a NVIDIA graphics card in it & runs great.
Steven,
you cold try
graphics win32_gdi or
use_software_opengl yes
in your config.pro
Also you could try
sketcher_refit_after_dim_modify no
Reinhard
Hi Steven...
I think the concensus is that this is DEFINITELY a graphics card issue. We've seen this before from other users and the remedies posted here are the usual fixes:
  • Replace the graphics card (use one supported for Creo Elements Pro)
Or... if that's not an option...
  • Try toggling settings in your config.pro file as Reinhard suggested
Thanks!
-Brian
