Display of required components in a assembly view in draftin
Not applicable
Hi, Can any one tell me how to control the display of interested component display in a assembly view in drafting.I mean to show component 2 and 3 without showing the other components in an assembly of 5 components. Or If possible could i show the unwanted component in a assembly view in dotted lines so that i can specify the component of interest. Regards vishal
2 REPLIES 2
cfitzgerald-2
1-Newbie
(To:)
Hi Vishal, Recommend creating a simplified rep in the assembly. Exclude the top level and set the components you want shown as Master Rep. Return to the drawing and set the view properties to the simplified rep. or In drawing mode select View>Drawing Display>Component Display. This should allow you to blank components or set components as phantom lines. Regards-
Not applicable
(To:cfitzgerald-2)
Thank you very much
