Drawing Common Name
SOLVED
Newbie
Drawing Common Name
Is there anyway to automatically set the Creo parametric common name of a drawing to the same as the common name for the linked Creo part / assembly?
I want to have the common name field automatically copied from the part to the drawing for use in Windchill.
John
Tags (3)
Re: Drawing Common Name
Yes, there is and it is seldom used:
Drawing relations can be added under Tools > Drawing Program in Creo, but this is a very old functionality (unchanged for almost 20 years) with a display window and line editing by menu manager commands.
Gunter
P.S. It is probably a philosophical question, whether it is used so rarely because it has never been updated or whether it has never been updated because it is used so rarely.
John, are you referring to creation or rename (as the picture shows)?
For the initial creation R&D has confirmed that there is no functionality to do it.
I found this, because there has been an interesting idea from a customer, using a drawing relation:
PTC_COMMON_NAME:D=PTC_COMMON_NAME:0.
However, of course it worked only for the first part in session, as the ":0" is a session ID.
In this context R&D confirmed that there is no alternate method available.
As for rename, I see no way to do it either.
Thanks for reply Gunter,
Unfortunately this relation is not being accepted in my drawing but listing errors instead.Error+Relations.PNG
It appears to be referring to the part relations, is there a seperate area for drawing relations.
John
Gunter
Gunter,
That is a nice solution but unfortunately it only works for the initial session but it might be enough to get me out for new parts and then modify manually afterwards.
John
