Drawing: Imported parts
agaribay
3-Visitor
A co-worker imported a part into a ProE Assembly, and now in the drawing, the part is shown in purple and wireframe.
Isn't there a way to modify the look?
Sorry, but it's been awhile since I've addressed this.
WF4.0
Thanks!
-Art
[cid:image001.png@01CE044F.8DB61150]
This message (including any attachments) contains
confidential and/or proprietary information intended
only for the addressee. Any unauthorized disclosure,
copying, distribution or reliance on the contents of this
information is strictly prohibited and may constitute a violation
of law. If you are not the intended recipient, please notify the
sender immediately by responding to this e-mail, and delete the
message from your system. If you have any questions about this
e-mail please notify the sender immediately.
I believe those purple components are surface features now because they wouldn't solidify on import. I'd go back to the model and open those components and try to make them solid.
Joshua Houser
(have I talked to you about FIRST robotics yet?)
Pelco by Schneider Electric
Methods & Tools Sr. Engineer
Not applicable
(To:agaribay)
Those are surface quilts. Depending upon your settings file, one shade
of purple indicates one-sided edges, and the other shade indicates
two-sided edges.
One sided edges are those that only have a surface on one side, i.e.
will not hold water, no matter how close it looks like they are the same
edge. Once you have a volume as a merged two-sided quilt, you can then
solidify it.
Note, you can enable hidden line removal on your drawing for quilts
under the view properties. Be aware that printing drawing with HLR on
quilts increases time and file size.
Dan Harlan
Mechanical Engineer / CAD Administrator
480.940.0036 x178 Office
480.940.0039 Facsimile
481 N. Dean Avenue
Chandler, AZ 85226
dharlan@aitint.com
www.aitint.com
Niru_V
7-Bedrock
(To:agaribay)
Thatcould be because of Importing data in IGES format and the the model is not Solidified.
First open the model in Part Module and try to solidify it, If it doesn't solidify, You need to repair it with Import Data Doctor Module.
There is some videos in YouTube about Import Data Doctor Module.
Here I'm attaching an PPT I made for my customer.
As per my knowledge IGES will Export/Import the Surface & Wireframe data only.
Iprefer STEP models as it can Export/Import direct Solid Models.
Anyone, Pleasecorrect me if I'm wrong.
