In this video tutorial you can find one answered question:
I would like to solve in Creo Mechanism. As You can see in the picture that I attached, there is one body (object 1) which is supported on three feets. Another body (object 2) moves in one direction (along x-axis) on guides that are mounted on object 1. My problem is to set proper connection between feets and object 1 and object 2, which would allowe me to measure force reaction change in each feet, while movement of object 2. Is it possible to do such simulation in creo?
My answer is... try to check my video 🙂
