Greetings Team.
I'm a Mechanical Design Engineer currently wanting to build an ECAD 3D model library so that everytime we import IDF files into CREO Parametric, we get the true size and form of the electrical components instead of the grey blocks. I have been successful applying the concept in our current project and am hoping to continue after resolving a roadblock.
The challenge is that in complex boards with large qty. BOMs, having this level of detail bogs down even a high spec. workstation.
My current solution is to shrinkwrap the board assembly and use the resulting prt. file to replace the board in its higher assembly. This is detailed in the link below:
http://www.slideshare.net/pdtinnovation/proe-tip-004
I would like to request please for some alternative solutions, ideally file size and regeneration time reducing techniques and processes that can be applied to the part level (electrical component model, in this case) so that the solution automatically applies to the assembly.
Thank you.
Arie
