Edit Explode State Lines to repair broken references
danderson
11-Garnet
Good Morning Everyone,
Really hoping PTC has fixed this issue when a component is replaced and references for explode lines are lost.
It sure would be nice to be able to edit references in Creo 4 for lost references related to explode lines for explode states in assembly mode.
Yes if you use the edit references dialog in creo 2 or later you can avoid this issue. But if one fails to do this then you are left to delete and recreate them.
PTC Please add this to Creo 4!
Surprised there are not more votes on the enhancement below.
Don Anderson
Reference:
Explode lines editing in an expolde state; Re-establish a new reference.
0 REPLIES 0
