Entity Color
Entity Color
Hello all,
Does anyone know how to modify the color of a component in a assembly or a color of a surface in a part??
I find only the function ProCurveColorSet....but for other features???
Thanks in advance
7 REPLIES 7
Entity Color
Marco,
That is an excellent question. Pro/TOOLKIT does not have the API calls
to modify the color of assembly components or surfaces. However,
Pro/DEVELOP does have that functionality. Read the API Wizard under
User's Guide->Graphics and Object Display->Cosmetic Properties->Surface
Properties. The function you are looking for is
prodb_set_surface_props(). Sadly these functions have not been replaced
by equivalent Pro/TOOLKIT functions.
Patrick Williams | Sr. Application Engineer | CAM Systems | Steelcase
Inc. | 616.698.4078
Entity Color
Marco -
Once you have the component identified, you can you something like this
to change the color properties of a component. LIke Patrick said, there
isn't a Pro/TOOLKIT function to do this... I'm reverting back to the
old Pro/DEVELOP functions, so don't forget to include the libraries for
that.
RE: Entity Color
Dear Paul,
i was also searching the same for 1 of my requirement and i find the answer over here. thanks for posting the help over here.
But i have small problem. probably i am not feeling comfortable with prodevelop functions. reason might be i havn't done much on prodevelop front than protoolkit or very little help is available.
i used the same code prodb_set_surface_props(assembly, SEL_3D_PART,
p_asmcomp.id, 0, &properties); but my compiler is giving error 'SEL_3D_PART' : undeclared identifier.
should i need to pass selection object or i need to add any header file? help required.
Thanks & Regards
Nikhil Gothankar
In Reply to Paul Crane:
Marco -
that.
Entity Color
Nikhil,
You need to
#include <select3d.h>
It is clearly specified in documentation.
Vinay
2009/3/13 Nikhil Gothankar <->
> Dear Paul,
> help required.
> Thanks & Regards
> Nikhil Gothankar
> Marco -
> that.
RE: Entity Color
Dear Friends,
i am using the following code for coloring a part, but all my functions of surface properties returning -2.
ProError setpartColor(ProMdl mdl, double r,double g, double b){
Pro_surf_props *surProps;
ProModelitem mdlItem;
ProSelection sel;
int ret=0;
status=ProMdlToModelitem(mdl,&mdlItem);
ProTKFprintf(fp, "\n\t *id=%d",mdlItem.id);
status=ProSelectionAlloc(NULL,&mdlItem,&sel);
ret=prodb_get_surface_props((Prohandle)mdl,SEL_3D_SRF,-1,0,surProps);
ProTKFprintf(fp, "*\n\t ret0=%d\n", ret);memset(surProps,'\0',sizeof(Pro_surf_props));
surProps->color_rgb[0]=(r/255);
surProps->color_rgb[1]=(g/255);
surProps->color_rgb[2]=(b/255);
surProps->transparency=1;
ret=prodb_unset_surface_props((Prohandle)mdl,SEL_3D_SRF,-1,0);
ProTKFprintf(fp, "*\n\t ret1=%d\n", ret);if (ret==0)
ret=prodb_set_surface_props((Prohandle)mdl,SEL_3D_SRF,-1,0,surProps);
ProTKFprintf(fp, "*\n\t ret2=%d\n", ret);
return status;
will it work?
Waiting for response.
Nikhil Gothankar
In Reply to Vinay Marje:
Nikhil,
You need to
Vinay
> Dear Paul,
> help required.
> Thanks & Regards
> Nikhil Gothankar
> Marco -
> that.
Entity Color
Following code to get part color works for me. Try using SEL_3D_PART and
correct model Id.
int status, model_id;
status = ProMdlIdGet(mdl, &model_id);
status = prodb_get_surface_props(mdl, SEL_3D_PART, model_id, 0,
&properties);
status will be PRODEV_SURF_PROPS_SET if color is set on the part.
I haven't tried prodb_get_surface_props(), but hope it works.
Vinay
2009/3/20 Nikhil Gothankar <->
> Dear Friends,
> ProSelection sel;
> int ret=0;
> (Pro_surf_props));
> return status;
> will it work?
> Nikhil Gothankar
> Nikhil,
> You need to
> Regards,
> Vinay
> > Dear Paul,
> answer
> front
> 'SEL_3D_PART'
> > help required.
> > Thanks & Regards
> > Nikhil Gothankar
> > Marco -
> > that.
RE: Entity Color
Friends,
Pro_surf_props surProps;
status=ProMdlCurrentGet(&mdl);
ProTKFprintf(fp, "\n\t *id=%d",model_id););
surProps.color_rgb[0]=(0.0);
surProps.color_rgb[1]=(0.0);
surProps.color_rgb[2]=(0.0);
if (ret==0)
ret=prodb_set_surface_props((Prohandle)mdl,SEL_3D_SRF,model_id,0,&surProps);
same result : ret2=-2
Nikhil Gothankar
correct model Id.
&properties);
Vinay
2009320 Nikhil Gothankar <->
> Dear Friends,
> ProSelection sel;
> int ret=0;
> (Pro_surf_props));
> surProps->color_rgb[0]=(r255);
> surProps->color_rgb[1]=(g255);
> surProps->color_rgb[2]=(b255);
> return status;
> will it work?
> Nikhil Gothankar
> Nikhil,
> You need to
> Regards,
> Vinay
> 2009313 Nikhil Gothankar <->
> > Dear Paul,
> answer
> front
> 'SEL_3D_PART'
> > help required.
> > Thanks & Regards
> > Nikhil Gothankar
> > Marco -
> > isn't a ProTOOLKIT function to do this... I'm reverting back to the
> > old ProDEVELOP functions, so don't forget to include the libraries for
> > that.
