Envelope usage survey
Newbie
We're looking for a some data around envelope usage in Creo. I'd appreciate a few minutes from users out there who use envelopes to answer the following questions:
  1. What is your basic use case for using envelopes in your assemblies?
  2. Do you use multiple envelopes in an assembly?
  3. Do you use default envelopes? (for Creo Elements/Pro 5.0 users only)
  4. Do you use envelopes at lower assembly levels? (for Creo Elements/Pro 5.0 users only)
  5. Do you ever convert simp reps with envelopes into External simp reps?
  6. Which data management tool do you use?
Thank you in advance!
5.
