Excluding dependents when checking in assemblies
Visitor
I'm using Creo Parametric 4.0, Build M020. I would like to check in an assembly without checking in any modified child parts. This was possible in Creo 2.0. In the embedded browser, there is no longer an option to exclude individual child parts, nor can I change the collection settings to anything other than “required dependents.” How do I exclude child parts I do not wish to check in with the parent or, failing that, how do I change the collection settings so that child parts will not be checked in with the parent? TIA!
