Explode Lines Do Not Show Up on Drawing
jdurston
Hi PTCUSER Users,
I am hoping this is an easy one. I created an explode state in my assembly with explode offset lines. I can't get them to show up in the drawing when I place the view.
Does anyone have any idea how to fix this?
I am using Pro/ENGINEER Wildfire 4.0 M110
Thanks in advance.
JD
OK, so I saved the explode state in the model, and changed the exploded view to wireframe, and they showed up, then back to "no hidden", and they stuck around.
I am betting saving it worked.
Sorry to bother.
I was under the impression saving the exploded state only saved the relative positions of the exploded components. I thought the dashed lines that showed up as features in the model tree was separate from this.
It is good to hear you resolved the issue. On a side note, sometimes depending on the size of the assembly the line graphics can look awkward at best. For small components, on the order of acentimeter ortwoI found that I had to change my line style to a double dash to get them to show up clearly in the drawing. Otherwise I may only get one dash or a portion of a dash making the line confusing.
