Exploded Assemblies
Highlighted
Newbie
Exploded Assemblies
I'm having problems controlling the final exploded position of
components in an assembly. First, I set the component's status to
Unexplode. Then I edit the position to move the component to where I
want it. Everything looks fine until I hit Ok, then the component jumps
out to some predetermined position that is nowhere close to where I had
it or need it to be.
Has anyone else experienced this and found a way to override the default
explode position? Just to add to the fun, it doesn't happen on every
component either.
Thanks!
Wes
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
