Failed model regeneration in assembly
thill-2
I have designed several parts to be put into an assembly. My assembly came together perfectly, then for some reason when I went to re-open the file at a later time, all but 1 of my parts would not regenerate. When I look in the feature information, this is what I am presented with.
COMPONENT #5 (BOTTOM1) failed regeneration.
Feature geometry is not up-to-date.
Reasons for failure:
Component model is missing.
I am sure that the model is in the correct location.
One thing I did shortly before this all happened was add a parameter "ID-string-(x)" to each individual part.
I can't even open the part file. I just get the message "(part name) could not be retrieved"
Does any one have any ideas about how to resolve this problem?
1 ACCEPTED SOLUTION
Thank you for the response, but I have resolved the problem. For some reason my local storage (U:) drive had become disconnected. All I had to do was restart my computer and the problem solved itself.
part mentioned in message "(part name) could not be retrieved":
  • can be corrupted -OR-
  • has been saved in newer software version
You can check software version if you open part file in Wordpad - see picture.
MH
Martin Hanák
Mahesh_Sharma
22-Sapphire I
(To:thill-2)
Trevor,
You may mark your reply to post as correct answer.
gkoch
(To:thill-2)
Don't bother! I'll mark it as Correct Answer, to signal to users that this issue has been resolved (i.e no need to help, source of information)
