"Jackie Giannetta" wrote:
I hope someone can help me out with this problem. I've created some Family Tables for specific size smt chip caps and res. Our designer will bring a pcb assembly into Pro/E having the smt chip cap and res and the Family table will import(open) as well. The designer than will suppress the chip caps and res. Save the assy, which works and continue on. The problem comes up when he resumes those chip caps and resistors and tries to resave the Assy. Pro/E will come up with an error stating that all the instances in the Family Tables must be verified. This does not happen if he uses Hide instead of Suppress. Why is this? Is something missing from the Family Table? Does Pro/E see a suppression as a form of modification? The parts from the Family table will then show up in the Workspace as being modified when they weren't. I appreciate any help or suggestions anyone can give. We can't seem to figure out what's going on. Thanks so much for your time!
To answer your question simply, yes the suppress function is an actual modification to the assembly and it affects the master representation of the model. The hide function simply affects the visibility of the part and is not an actual modification to the assembly.
This difference is similar to the difference between simplified representations and Style Views, Simplified reps are used to show different part configurations and styles is simply to control visibility states of components.
