Hi all,
Initially the generic assembly XXX have instances XXX-1, XXX-2, XXX-3 in PDMLink, but afterward someone edited the assembly to deleted instance XXX-3 and checked in to PDMLink, the latest assembly just with instance XXX-1 and XXX-2, now I want to retrieve the instance XXX-3 but don't know how to do.
I don't want to use another instance name to replace XXX-3 because XXX-3 already used on other assembly;
I don't have the right to delete any revisions in PDMLink.
Does anybody know please help, thanks!
Best regards,
Rick
Follow this support doc. I've used it in the past with success.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS4975
Thank you, I tried and succeed.
