File/Open Dialog Behavior
Newbie
Hello all,
This is something that has been bothering me ever since we upgraded to WF2...
If I have a drawing open in WF2, and I then click the Open button on the toolbar to open another file, it brings up the File/Open dialog. My setup causes this window to come up in the windows "List
View" where there are multiple columns of files/folders present. If I scroll without clicking in the window (by scrolling the mousewheel, or by dragging the slider to the right), and I then click on
a file or folder that is NOT in the first column (I have 3 columns visible, so this would be clicking in the 2nd or 3rd column), the contents of the dialog will jump over to the left by one column.
This only happens when I have a drawing as the active window when I click the "Open" button. Once this behavior has occurred, it will not happen again until you have left the dialog and gone back
(either by cancelling or just opening a different file later on).
This is very irritating when you try to quickly double click a file to open it, since the first click will pick the file (and everything over to the left by one column), and the second click will
select the file that was immediately to the right of the file that you first clicked (since it is now under the mouse cursor). If you aren't paying attention and you just click that newly selected
file again to open it (or double click it), you end up opening the wrong file.
Has anyone else noticed this behavior? I have a call into PTC to see if it is a bug, and they haven't been able to duplicate it. After a few weeks, their suggestion is to try a newer build. I have
made arrangements to get the newest build through our IT group after M181 is released. I am currently on M140.
Thanks!
Jeff Roetman
Product Dev. Engineer
Phone: 616 654-7348
FAX: 616 654-5279
RE: File/Open Dialog Behavior
I've noticed the same behavior on build M080.
Mike Singer
Re: File/Open Dialog Behavior
Follow-up comments and another question.
I have heard numerous responses of agreement and annoyance, so clearly this is not a limited issue...
Another question: Is there a way to make the default setting to have the File/Open dialog come up in "Details" mode? This is toggled in the dialog with the "Display Configuration" button, but it
only sticks until you restart Pro/E...
Thanks again for all of your responses. I am still waiting for the magical response "Oh yeah - I fixed that by...."!
Jeff Roetman
Herman Miller - Design Yard
Phone: 616 654-7348
FAX: 616 654-5279
Jeff Roetman <->
Sent by: -
To
"PTC/USER Model Discussion" <->
01/25/2006 01:35 PM cc
Subject
Please respond to [model] File/Open Dialog Behavior
Jeff Roetman <->
Hello all,
Thanks!
Jeff Roetman
Phone: 616 654-7348
FAX: 616 654-5279
You are currently subscribed to model.
To unsubscribe send a blank e-mail to -.
For assistance, email us at - or find other contacts at www.ptcuser.org/org/contacts.html.
PTC/USER and the PTC/USER logo are registered trademarks of PTC/USER, Inc.
Pro/ENGINEER is a registered trademark of PTC.
Message authors are solely responsible for the content of their posts.
