The senerio....
Have a family tabled assembly, swapping out 3-4 parts, turning off some etc....
In my drawing I want to show the Part Number of the item, but, I seem to only get the Instance Name that is the model being turned on and off. Is there an easy way to show the PART_NUMBER parameter that is in my instaces....
ITEM 2 - 112_01(the instance name is shown in the table)
I would like:
ITEM 2 - 11201 (the part number shown instead)
Captn
Go to Table>Repeat Region>Relations
Select the Table
File>Import Relations
Select replace_one_component_rel.txt and edit accordingly:
Or Type:
IF asm_mbr_name == "112_01"
NAME = "11201"
ELSE
NAME = asm_mbr_name
ENDIF
Then click on your table part number and select:
rpt>rel>User Defined and enter NAME
In Reply to Captn Pea:
The senerio....
I would like:
Captn
Thanks for the help.... but, I think I need to be more clear.
My instances have a parameter in them... PART_NUMBER, that is what I want to show instead of the instance name.
