Find Constraint that is Locking Motion
SOLVED
Highlighted
Amethyst
Somewhere buried in this assembly there is a constraint that is preventing the ability to drag a sub-assembly that was installed with a Pivot constraint.
Is there an easy way to find it?
Tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: Find Constraint that is Locking Motion
I always move insert up the tree until the pivot works then move down one-bye-one till is locks up.
Creo is an endless adventure: Always more to learn.
2 REPLIES 2
Highlighted
Highlighted
Ah yes... Perfect!
Thank you!
