Find flexible component in an assembly using the find tool
jbob
11-Garnet
I was trying to use the find tool to locate any flexible components in our assemblies. I know I can look at the model tree and see the different icon next to the component part number, I believe you can find them using model check. Is there a way to find flexible components using the find tool? I am using Creo 2 M170
Mahesh_Sharma
22-Sapphire I
(To:jbob)
Bob,
Search for flexible components using find tool is an enhancement from Creo 3.0, not an option in Creo 2.0.
In Creo 3.0, Search > Look for Component > Status > Attributes > Value as Flexible > Find now.
rleseberg
(To:jbob)
Very good question.
I await information on this as well, as we are using more and more flexible parts.
Mahesh_Sharma
22-Sapphire I
(To:jbob)
Bob,
Thanks for the information, the best I can do in Creo 2 would be using the model tree. Select tree columns, select Info from the type, select Varied. You will see Modifying next to the flexible component.
