Flexible Modeling Redefine
SOLVED
Aquamarine
I'm using Creo 3.0.
How do I edit a flexible assembly component? Seems like a dumb question.
WayneF
Re: Flexible Modeling Redefine
simply edit definition of assembling of flexible component. You will see tab containing "flexibility definition".
Martin Hanák
Martin Hanák
Hey Martin,
Where is this tab?
By the way - this is for flexible assemble components. I think my description is misleading.
By the way...I still need to get back to the "relation" post i did a bit ago that you were helping with. I've been in "get it done mode",
Wayne
Crap..got it. I have to edit component to dig down into varied items. That just did not seem like the obvious thing to do. I figured it should be in the rmb make flexible area. Thanks!
