Flexible Part bolloon doesn't showup in the Drawing
skarmegam
3-Visitor
I'm using Pro E WF3.0 M180. One of my assemblies contains a flexible part in two places(2 Qty).When I create the drawing the BOM table shows the Flexible part correctly but doesn't show up the Bolloons.It is fine when the Flexible parts Quantity is one. Is there anybody comeacross this issue?
3 REPLIES 3
We are running WF3.0 M170 and actually came across the same problem. A flexible component can be used and will be shown in our BOM repeat region if it is only used as one component or in one pattern. If we use more instances, more patterns, different flexible dimensions, the line in our repeat region disappears, just like the BOM balloon. Our Software supplier took a look at it also and didn't have that problem on exactly the same assembly, ... just until they realized they were working with WF4 (don't know the datecode) We also tried this on a WF4 and also found that his problem is no longer an issue on WF4 !
issue is resolved on WF4
yes, thsi was a wf3 problem and was resolved on Wildfire 4.0
