Get a pointer of the assembly coordinate system?
Newbie
Fellow Toolkiter's
How do extract a pointer of the coordinate system in an assembly? I
have the handle of the assembly (ProMdl assem). What's next?
My main goal is to add additional coordinate systems to an assembly
based on the original coordinate system.
Jason Benoit
re: Get a pointer of the assembly coordinate system?
Eugene,
You have to traverse the features of the assembly using ProSolidFeatVisit(). You have to implement feature visit/filter functions (passed as function pointers to ProSolidFeatVisit) for each feature that is visited. Maybe you're looking for a coordinate system of a specific name. For that example, inside of your filter function you may get the feature type using ProFeatureTypeGet() and looking for features of type PRO_FEAT_CSYS (see ProFeatType.h). If the feature isn't a coordinate system, you'd pass PRO_TK_CONTINUE to not pass it to the visit function. After you'd established that the feature was a coordinate system, you'd get its name using ProModelitemNameGet() and compare the name to what you're looking for. Again, you'd return PRO_TK_CONTINUE if it didn't match and PRO_TK_NO_ERROR if it did. In the visit function, you'd add the feature to some type of "container" or directly to a ProFeature* handle that you pass to the visit funtion via the ProAppData argument.
This visit/filter type of functionality is common across many areas of Pro/Toolkit and one that you must be familiar with. Take a look at the "Pro/Toolkit User's Guide > Fundamentals > Pro/Toolkit Techniques > Visit Functions" for a better description of how this is done.
Good Luck,
Michael Fussy
Sorry.... Jason, not Eugene.
