Getting NDI error
Vinee
Getting NDI error
When trying to check in one assembly in to Windchill, I'm getting error message as
"NDI ERROR:two dependencies have same uniqueID "R/-1/XXX-XXXX-XXX.prt/null"
Please let me know how to solve this error.
1 ACCEPTED SOLUTION
IceDog
2-Guest
(To:Vinee)
This is the way I ususally solve this:
  1. Rename offending file in commonspace to non-desired name
  2. Sync workspace with commonspace to update filename
  3. Open parent file make edit, save and checkin
  4. Rename offending file in commonspace back to desired name
  5. Sync workspace with commonspace to update filename
  6. Open parent file make edit, save and checkin
  7. End of process
5 REPLIES 5
IceDog
2-Guest
(To:Vinee)
  7. End of process
mbrehmer
6-Contributor
(To:IceDog)
^ This worked for me.
This is one of the worst bugs in Windchill.
kaerts
(To:IceDog)
1e time in 10 years....... getting this NDI error
^^ This alsow worked for me, windchill 10.1 datecode M010.
I had the same issue and tried these steps and it worked. Thanks!
sbs
(To:Vinee)
I had similar issue.
Given steps worked for me too.
Thnx a lotz lotz for your help!!!!
