Getting the value of a component level parameter in an assembly
Highlighted
Newbie
Hi-Tech Gears Limited, Gurgaon, India
Sent using PostMaster by QuantumLink Communications Pvt Ltd
One Internet account, unlimited personal e-mail addresses
Get your free copy of PostMaster at http://www.postmaster.co.in/
3 REPLIES 3
RE:Getting the value of a component level parameter in an assembly
Debanjan,
You have to visit the components of the assembly using ProSolidfeatVisit
filtering to the type PRO_FEAT_COMPONENT. You can convert the ProFeature
object for each component to the ProAsmcomp object by casting. Each solid is
a feature/component of the assembly. You can then get the parameter from the
solid. For more information look up Assemblies -> Visiting Assembly
Components in the API Wizard under the User's Guide.
Patrick Williams
Applications Engineer
Steelcase Inc.
Patrick Williams
Steelcase Inc.
Pauls answer sounds right to me, too.
RE:RE:Getting the value of a component level parameter in an assembly
Who is Paul and where is his answer?
Patrick Williams
Steelcase Inc.
