I have two files as templates in WF4 and PDMLink 9.1.A drawing that has an assembly file attached. However, there is no model within the assembly. It only has default datums and a few other things set up. I select File > New > Assembly, type in a Name and select OK. The next dialog showswe have the assembly listed as a Template. I leave the Copy associated drawings checked and finish.
At this point I look at my workspace and I see the drawing and its ghost object assembly.When I save the assembly it says Object of the same name already exists in the Workspace. I select Okand look in my workspace again. No more ghost object.
If I Uncheck the Copy associated drawings on the New file dialog box then I do not get the ghost object.
Is there any way to prevent the ghost object without unchecking the Copy associated drawings? If not does this hurt anything? I think it should be ok but just wanted to check.
Steve Galayda
