I build many large, highly connected assemblies that are typically at least 3 indenture levels deep. Specifically these are complex mechanical layouts using primarily skeleton parts and skeleton assemblies. These models perform amazing things for my company allowing us to change rocket size and length dramatically and update nearly 1000 unique objects (and many thousands via assembly constraints) within 5 minutes. HOWEVER, I make extensive use of external copy geometry. Which leads to a big head ache.
Three or 4 times per year I am asked to make a new configuration that is to be (at least initially) exactly like the last one only with different sizing (think length and diameter of rocket stages). The rename functionality works beautifully for me EXCEPT that IN MY SITUATION, I invariably DO want the external copy geometry items in all components to now point to the NEW object. That is not current behavior when using rename within PDMLink.. and I "get" that.
Does anyone know a way to perform these large "cloning exercises" in a manner that WILL do what I want?
