Hatching in Creo Drawing
SOLVED
Hi everyone,
1.How to draw a stright line In creo drawing mode from sketch tab
what i had tried
i have done hatching in creo drawing with adding section in the model and show it in the drawing
now my question is i want hatch the solid part in drawing without adding section in the model in an assembly drwaing (just like in autocad) so i tried one thing in creo drawing go to sketch>select line > draw line where you need to be hatched > then select hatch fill command. but while drawing the line the line does not take any refrence then when i try to draw a straight line it draws with an angle and the loop does not complete so hatch /fill command does not work. how to solve this
any suggestions will be very helpfull
Tags (3)
Re: Hatching in Creo Drawing
One way to get straight lines.
7 REPLIES 7
if anyone knows how to default this on, that would be great.
Thank You Matt
Right click and input 0 degree in it.
use line,not sketch preference.
Or you can use cosmetic sketch in 3D model to make the hatch as well.
Or Sketch feature, too.
Martin Hanak
Martin Hanák
