Help with lisp for creating fillet weld
kpederson
3-Visitor
We are in the process of creating a lot of fabricated brackets and we create a separate model for welds in our assembly. I'd like to speed up the process and create a lisp with the ability to select a point and the fillet weld length in the lisp and have it extruded to a certain distance. Can anyone help?
Do you have any experience in developing LISP code for Modeling?
You should create a dialog with different inputs, and start the necessary commands, but this won't be easy without any experience.
You will need first of all to know the LISP language, and then the Integration Kit of Modeling.
Best regards,
Wim.
