Hey all PTC champs...need help...i am not able to find New featuer i.e Security marking In Creo 3.O
How to activate that...
Name of feature may be " Security Marking 3d Animation" it is used for drawing- formatt to asign any note as security mark..
Also Anyone used freestyle modeling....when I using that 3d Dragger it not smoot as like Creo 2.O....It is bug or any setting should be there???
Remember this is only for "Notes and Symbols" and "NOT Annotation Features".
Dinesh,
Security marking is available in format tab enabled after creation of note (Annotate Tab) in model.
I've managed to find the following blurb in CS130154. I'm not seeing anything in the help documentation. Is there anything else?
Security Markings for 3D Annotations
That is what I am asking icon of Security marking is not found in Format tab also.....when i am creating any note in format tab it should be there but not found
Dinesh,
1. Create a note in model
2. After completing note creation, annotate > select note > activate format tab > security marking.
I wonder why it only works using the "old method" of creating annotation features. (See Brian's comments on this here:Re: 3D Annotations VS 3D Annotation Features)
Sorry Late to this....Thank You for your...will try and update you
