Hiding Family Table columns on drawing
Newbie
Hi All,
I have a model of some trim strip that has some family table instances,
and I've created a drawing showing the generic along with the family
table to show cut angles & lengths for the instances.
One of the instances has a spinal bend to allow the part to be shown in
it's finished shape in the assembly.
My problem is that I would like to hide the columns in the family table
that pertain to the spinal bend - these have nothing to do with cutting
the part, so I'd like to leave them off to keep the drawing simple.
Is there a way to do this, or am I missing some obvious other approach?
Thank you,
James Kasson
Layout Manager
Steehead Metal Corp.
Tel: (208) 463-0441 x107
Fax: (208) 463-0461
READ CAREFULLY. By reading this e-mail, you agree, on behalf of your
employer, to release me from all obligations and waivers arising from
any and all NON-NEGOTIATED agreements, licenses, terms-of-service,
shrinkwrap, clickwrap, browsewrap, confidentiality, non-disclosure,
non-compete and acceptable use policies ("BOGUS AGREEMENTS") that I have
entered into with your employer, its partners, licensors, agents and
assigns, in perpetuity, without prejudice to my ongoing rights and
privileges. You further represent that you have the authority to release
me from any BOGUS AGREEMENTS on behalf of your employer.
Go to the table
Table > Repeat Region >Filters > (select the region) > By Rule > Add
Type the following:
&fam.inst.param.name != <the header=" of=" the=" family=" table=" column=" you=" want=" to<br="/>remove>
( recall that != is pro/e relation-speak for "does not equal")
The header will probably be something like [SPINAL BEND]. If there is a
space in there, like I show here, you'll need to put it in quotes, so it
would be
&fam.inst.param.name != "[SPINAL BEND]"
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
Re: Hiding Family Table columns on drawing
