How can I open a previous version drawing with corresponding assembly model and parts?
Visitor
Good afternoon:
Can anyone guide me to how I can load a previous version drawing and corresponding assembly model into workspace?
I know how to look at the history tab in the drawing information but I don't know how to open it in Creo.
When ever I try to open a previous version, the drawing updates with the latest part models.
I need the models at the version where the drawing assembly was saved, not the latest.
Creo 2.0 (M090) and Windchill PDM Essentials 10.2 (M010).
Thank you.
~Benito
Re: How can I open a previous version drawing with corresponding assembly model and parts?
Benito,
You need to change the dependencies settings from "Latest" to "As Stored". I am on Windchill 10.1, so hopefully the screenshot makes some sense.
Click on the Edit Dependencies Icon and choose As Stored. In the dialog box that appears, I think you should be able to just click on the OK button.
Once you do that, just visually check to see if your dependencies have changed from Latest to As Stored.
Oh, and before you start, make sure your workspace doesn't have any later versions of the objects.
-marc
