How can I unlock model parameters?
WilliamJugovich
I have some parts and assembly that have paramters that are locked because they were created in Interlink. How can I unlock these parameters so they can be deleted?
1 ACCEPTED SOLUTION
Hi
I had an understang that we can not delete or unlock system parametrs created by windchill or intralink
But I was wrong. I am sorry for my earlier post
This is possible through a config setting
allow_create_pdm_param yes
After this you can delete or edit these parameters(when you are not connected with windchill server)
Regards
K.Mahanta
5 REPLIES 5
Hi William
As per my understanding; you can not unlock/delete these parameters
Regards
K.Mahanta
Hi
Regards
K.Mahanta
I could not find that option in my config.pro
You have to add the parameter manually, it is not found during a search of the config.pro
I am facing same issue in 4.0
Your solution is not working in 4.0
Pls suggest solution for 4.0
